  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
make Handle in graphics script easier to click
Larger marker for Handle - the handle function makes a tiny square marker which is hard to hit with the mouse. Make it easier to drag a handle without hitting the exact center of the marker.
New Window( "Example",
    exx = 20,
    exy = 50;
    Graph Box(
        Frame Size( 200, 200 ),
        Handle(
            exx,
            exy,
            exx = x;
            exy = y;
        Circle( {0, 0}, Sqrt( exx * exx + exy * exy ) );
the bottom edge of the square marker seems out-of-bounds.the bottom edge of the square marker seems out-of-bounds.
2 Comments
kayleewarren
@Craige_Hales Thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
Same for Drag Markers!
One can increase the marker size - but little help :  one still needs to drag the Drag Marker at the center.
