%3CLINGO-SUB%20id%3D%22lingo-sub-247296%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%26lt%3B%3CMAKEINTODATATABLE%20name%3D%22%22%20better%3D%22%22%20when%3D%22%22%20used%3D%22%22%20with%3D%22%22%20colspanbox%3D%22%22%3E%26lt%3B%20ingo-sub%26gt%3B%3CLINGO-BODY%20id%3D%22lingo-body-247296%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EVoglio%20tablebox%20che%20utilizzino%20ColSpanBox%20per%20denominare%20meglio%20le%20colonne%20quando%20interagiscono%20con%20%60%26lt%3B%20%3CMAKE%20into%3D%22%22%20data%3D%22https%3A%2F%2Fcommunity.jmp.com%2F%22%20table%3D%22%22%3E%3C%2FMAKE%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Edt%20%3D%20Open(%22%24SAMPLE_DATA%5CBig%20Class.jmp%22)%3B%0A%0Anew%20window(%22Row%20Borders%22%2C%20%0A%09tblbox%20%3D%20tablebox(%0A%09%09ColSpanBox(%221%22%2C%20%0A%09%09%09NumberColBox(%22age%22%2C%20dt%3Aage%20%26lt%3B%26lt%3B%20Get%20Values)%2C%0A%09%09%09StringColbox(%22Sex%22%2C%20dt%3Asex%20%26lt%3B%26lt%3B%20Get%20Values)%2C%20%0A%09%09)%2C%0A%09%09NumberColBox(%22Height%22%2C%20dt%3Aheight%20%26lt%3B%26lt%3B%20Get%20Values)%0A%09)%0A)%3B%0A%0Atblbox%20%26lt%3B%26lt%3B%20Make%20into%20data%20table()%3B%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EIl%20comportamento%20della%20tabulazione%20andrebbe%20bene%20per%20me.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3E(dt%20%26lt%3B%26lt%3B%20Tabulate(%0A%09Add%20Table(%20Column%20Table(%20Grouping%20Columns(%20%3Asex%2C%20%3Aage%20)%20)%20)%0A))%20%26lt%3B%26lt%3B%20Make%20Into%20Data%20Table%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-247296%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomazione%20e%20scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3C%2FMAKEINTODATATABLE%3E%3C%2FLINGO-SUB%3E
<<makeintodatatable name better when used with colspanbox
I want tableboxes that use ColSpanBox to name the columns better when interacting with `<<make into data table`.  Currently it just takes the lowest column name.
dt = Open("$SAMPLE_DATA\Big Class.jmp");
new window("Row Borders",
	tblbox = tablebox(
		ColSpanBox("1",
			NumberColBox("age", dt:age << Get Values),
			StringColbox("Sex", dt:sex << Get Values),
		NumberColBox("Height", dt:height << Get Values)
tblbox << Make into data table();
The behavior that tabulate does would be fine by me.
(dt << Tabulate(
	Add Table( Column Table( Grouping Columns( :sex, :age ) ) )
)) << Make Into Data Table
