취소
다음에 대한 결과 표시
표시  만  | 다음에 대한 검색
다음을 의미합니까?
언어 선택 변환 막대 숨기기
keyboard shortcut to stop all formula evaluations
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
To stop all formula evaluations, the user can click on "Suppress Formula Eval" in the table red triangle menu:
https://community.jmp.com/t5/Discussions/stop-all-evaluations/m-p/529859/highlight/true#M75318
But sometimes, jmp is so busy to run the evaluations (stuck in a loop?) that it's almost impossible to get to the menu.
my wish: a keyboard shortcut to stop all current formula evaluations.
--> the user can press it continuously till jmp gets the info end stops the evaluation
(like pressing Esc continuously if a JSL code is stuck - after some while, JMP detects it and stops the code)
btw: there is a command rerun Formulas in the same red triangle menu.
But this button just works if "Suppress Formula Eval" is not activated for the table.
my wish:
rerun Formulas should rerun the formulas every time the user clicks on rerun Formulas - even if "Suppress Formula Eval" is activated.
5 의견
상태가 변경됨: Acknowledged
@hogi - Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
상태가 변경됨: Investigating
hogi
Level XIII
related wishes:
Kill process without killing JMP
Avoiding complete shutdown while not responding
with the idea to have a general option stop Jmp from being stuck.
on the other hand, there are some functions with known speed issues:
Speed up Tables/Update
hogi
Level XIII
Thanks.
