🙏 is in spec (value)
☐ cool new feature
☑ could help many users!
☐ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2024
#myTop10_2025
#myTop10_2026
JMP provides many useful platforms and great functionality for exploratory data analysis.
But even after 18 versions of JMP - there is still some low-hanging fruit to be picked
- such as is in spec(value)
For a column with Spec limits, please provide
  1. a JSL function
    is in spec(:value)
    which compares the value of the current row with the spec limits of the column and returns 1 if the value is in spec,
    missing, if the value is missing
    and 0 if the value is out of spec
  2.  a functions
    is out of spec(:value)
    0 if the value is in spec
    -1 if :value[] < LSL
    +1 if :value[] >USL
Both functions should be available via the right click "new formula column" menu.
Then users can easily generate new transform column on the fly in every platform - to group and add color to specific data points.
Why is this idea important?
Is the value in spec is a question that is often asked. Right?
-> JMP users will love the new easy to use functions.
9 Comments
hogi
Level XIII
cool additional ideas:
https://community.jmp.com/t5/Discussions/is-in-spec-value/m-p/774330/highlight/true#M95601
@jthi wrote:
  • "Select out of spec rows" (right click menu on column header)
  • and then we could have a << Get out of spec rows which could be send to a column which would return missing if spec limits aren't set and empty matrix if they are set but there are no such values.
  • Though, what would happen if we get the multiple spec limits which we have asked for for quite some time?
<< get out of spec rows :
Where(not(is in spec(:value)))
    One of THE arguments for an official function :)
    ... with an additional argument to specify which spec is used for the calculation.
hogi
Level XIII
maybe even some aggregation functions like:
- Col N in spec (:value, groupby)
- Col N out of spec (:value, groupby)
- Col N above USL (:value, groupby)
- Col N below LSL (:value, groupby)
.... and Tables/Summary, Tabulate and Graph builder Summary statistics ?
Hmm, maybe not ...
They can easily be broken down into
- Col Sum(is in spec(:value), groupby)
hogi
Level XIII
by the way: grouping
Where they should be added: header statistics
(here one cannot use custom, broken down code)
hogi
Level XIII
hogi
Level XIII
@Jeff_Perkinson
the other issue we discussed yesterday.
This function will allow very cool custom transforms!
https://community.jmp.com/t5/JMP-Wish-List/Option-or-function-to-evaluate-a-custom-column-formula-at...
mia_stephens
Marking this as acknowledged, as we understand the request and are following this thread.
hogi
Level XIII
thanks.
hogi
Level XIII
The wish was mentioned / discussed in the last session of the Scripters Club:
Scripters Club Recordings: Tips and Tricks
hogi
Level XIII
@flo_kussener , @isabelleswaenep  as discussed.
