  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
include() syntax errors give file name
If I am including a script
include("child.jsl")
and the child has an error in it
x = aaa;
I get a nice error output
Name Unresolved: aaa in access or evaluation of 'aaa' , aaa/*###*/
at line 6 in some\path\child.jsl
But if the error is a syntax error
x = {"f", "d", }; // has an extra comma
then I don't get the information of where the error is located
Unexpected "}".
Trying to parse operand for "List" operator.
Line 5 Column 16: x = {"f", "d", ►};
I think it would be great if it told the file that is causing the error like a code error does.
This  becomes even more apparently a problem if the include is
x = {
	"f",
	"d",
Because then I get a very vague error message
Unexpected "}".
Line 8 Column 1: ►};
1 Comment
Hi @vince_faller, thank you for your suggestion! We have captured your request and will take it under consideration.
