  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
easy way to add rows (with values) to a data table
☐ cool new feature
☐ could help many users!
☐ removes a „bug“
☐ nice to have
☑  nobody needs it
For Table boxes, there is a nice command
<< add row( list of values)
to add rows. As an argument, one can submit a list of the values - extremely elegant and useful for dirty coding :)
https://community.jmp.com/t5/Discussions/Collection-of-quot-funny-quot-JSL-newbie-questions/m-p/5590...
The command
<< add row( ... )
can even be sent to data tables. Then a row is added, but  unfortunately, without values.
As Jarmo found out, there is a way to specify the values, but it's much more complicated:, especially if the data table has more than a single column:
dt << Add Row({"Column 1"n = 1});
My wish:
A command like
which also works for data tables.
4 Comments
jthi
There could be a reason why Add Rows is so strict.
How would you like that command to behave when user doesn't add enough values? You will end up with very messy table with this
Names Default To Here(1);
New Window("test",
	tb = Table Box(String Col Box("string col", {"a"}), Number Col Box("number col", {1}))
tb << add row({"b"});
tb << add row({"b", 2});
You can kinda do this already with data table subscripting (this is what I use from time to time, if I have to add values to ALL columns):
dt = New Table("test",
	New Column("Col1", Numeric),
	New Column("Col2", Numeric),
dt << Add Rows(1);
dt[N Rows(), 0] = [1 2];
dt << Add Rows(1);
dt[N Rows(), 0] = [1];
Second one will throw because you are trying to add less values to the row than there are columns
With custom function this could be handled, but how would know from which side to drop values? Left, right or maybe middle? Or what would happen if data types do not match?
hogi
Level XIII
Hm, there are many other functions in JMP which have a problem if the user doesn't proved the values that were expected ;)
On the other hand, it would be so super-easy to add rows and the values in one rush, just by handing over the list of values to data tables - like it's possible for Table Boxes.
hogi
Level XIII
Thanks @jthi . The idea with the data table subscripting is very useful :)
hogi
Level XIII
@Sarah-Sylvestre
low prio -> can be closed and reactivated once the important ones are finished.
