different behavior of "clear" for conditional data filters
☑ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
[edited and adjusted to the new design]
deficiency of Conditional Data Filters
View more...
Conditional in this Data Filters means that "age (1)" defines the items which are displayed in "name (2)". --> cool
Clearing the selection in age clears the selection in "name" -> not cool : (
Please add a control in the red triangle menu and via preferences to enable an alternative mode:
!! lock childs when clear !!
The new behavior:
If a selection is cleared via
>> the selection in child filters should not be reset anymore  <<
(sure: the row selection should be adjusted to fit to the displayed selection)
Why is this idea important?
the proposed behavior has 2 modes where it can show it's advantages:
A) The new lock childs when clear  mode allows a very cool way of selecting rows:
View more...
  1. use a parent filter to select rows with interesting features, e.g. pass/pail = fail
    with "Conditional" activated, other filters will adjust accordingly
    e.g. batches will just shows batches with fail units
  2. select all these batches
  3. clear the filter selection for pass/fail
    you just filtered all batches with fail chips
Once you understand the magic behind it, it's a feature you won't want to miss.
This way, during exploratory data analysis, you can  "stay in the flow" , just make one step after the other.
No need to create a column formula with grouped Col aggregation or similar workarounds.
B) Another benefit which cannot be rated high enough!
It will save users hours of waiting time over the course of their working lives:
View more...
The current "clear all child-selections" mode for conditional data filters results in long graph rendering times:
Every time a selection is cleared, all child selections are cleared as well. No chance to restrict the plot to a subset!
So, every the  user has to wait dozens of seconds, or even minutes.
I often work with large data sets which can just be displayed efficiently if a subset is selected (!).
The current behavior of Conditional Data filters is so time consuming that I decided to deactivate it.
Same for you?
The lock childs when clear mode will fix the issue:
With the new behavior, the user can make a "dummy" selection (just a single row), clear all the other data filters, apply a new filter and then clear the dummy selection.
What an improvement! right?
7 Comments
Sarah-Sylvestre
Level V
Hi @hogi, thank you for your suggestion! We have captured your request and will take it under consideration.
Sarah-Sylvestre
Level V
We are currently reviewing this request.
hogi
Level XIII
Important:
the new mode should NOT replace the old mode.
There should be a switch in the red triangle menu to activate the cool new behavior - when it's needed.
Or via the preferences: if it is needed frequently.
The new setting - activated when needed:
- adjust child filters if a parent filter is changed (like before)
- don't remove child filters if a parent filter is cleared via
hogi
Level XIII
@Sarah-Sylvestre , I edited the wish to make it easier to understand.
I hope the 2 examples illustrate how useful the new mode will be.
Is there an automatic process which updates the JIRA record accordingly?
if not, could you please replace the text with the new one?
Sarah-Sylvestre
Level V
The latest information is available for reviewers to access.
hogi
Level XIII
Sarah-Sylvestre
Level V
