  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
automatically write "Source" script when "Make Combined Data Table" is used in report with By column
Based on details in the discussion below, this idea is amended to request that a "Source" or "Make Combined Data Table" script be written to the table resulting from Make Combined Data Table in a report when there is a By column/variable.
"Make Combined Data Table" is one of JMP's most powerful features, yet one of its most challenging to script. No matter how many times I use this feature when exploring my data, I nearly always fail repeatedly when I try to incorporate it into a longer JMP-scripted data analytical pipeline. (I suspect I'm not the only one who has pinged [email protected] repeatedly on this same issue.)
When users run any of the platforms accessible from the Table menu the table that gets created is automatically created with a "Source" script that can be copied and pasted into a larger script in such a way that only minor and relatively obvious tweaking is needed to get the table script working in its new context. Yet when users request "Make Combined Data Table", usually no source script gets written automatically to the newly created table. This seems like a glaring and important gap in JMP's feature set that I hope can be filled with the next release.
Intriguingly, when users request "Make Combined Data Table" for a report table that occurs only once within the report, a script called "Make Combined Data Table" is in fact saved to the data table. But it is relatively non-obvious (to me) what kind of tweaking is needed to adapt the saved script to the situation where there are actually multiple tables that I very much need to combine.
I suspect there are many of us who would benefit if a functioning "Source" script were automatically saved to the newly created table every time "Make Combined Data Table" is requested -- especially when there are actually multiple tables to combine.
9 Comments
Jeff_Perkinson
Community Manager
Make Combined Table does create a "Make Combined Table" script in the resulting table, as long as you don't have a By variable in your analysis. The By variable makes it more difficult for JMP to know how to build the script. I assume you're wishing for support in the By variable case. Can you confirm?
ttreynor
Level III
Interesting! I hadn't figured out that the "By" variable was treated as an exception this way... probably because I am (almost) *always* using a By variable when I try to "Make Combined Data Table".
Yes, please extend this feature to provide support for the By variable.
Thx, Jeff!
tom
Jeff_Perkinson
Community Manager
In that case, I'm happy to say that JMP 15 will provide a "Make Combined Data Table" script when there is a By column.
ttreynor
Level III
Excellent!!
Jeff_Perkinson
Community Manager
Status changed to: Delivered
JMP 15 now handles By groups properly when using Make Combined Data Table.
ttreynor
Level III
fantastic! Thank you!
derchieh
Level III
Hi, will it also work when Where statement is used?
Jeff_Perkinson
Community Manager
@derchieh, can you give an example of what you're looking for? How is the where statement used in your code?
derchieh
Level III
Hi Jeff,
I frequently use Fit Model with Where statement as follows:
dt = Open( "$SAMPLE_DATA/Analgesics.jmp" );
Summarize( dt, genlst = by( :gender ) ); New Window( "Fit Model example using Analgesics.jmp", For( i = 1, i <= N Items( genlst ), i++, fm = Fit Model( Y( :pain ), Effects( :drug ), Personality( "Standard Least Squares" ), Emphasis( "Minimal Report" ), Run( :pain << {Summary of Fit( 1 ), Analysis of Variance( 1 ), Parameter Estimates( 1 ), Lack of Fit( 0 ), Scaled Estimates( 0 ), Plot Actual by Predicted( 0 ), Plot Regression( 0 ), Plot Residual by Predicted( 0 ), Plot Studentized Residuals( 0 ), Plot Effect Leverage( 0 ), Plot Residual by Normal Quantiles( 0 ), Box Cox Y Transformation( 0 ), {:drug << {LSMeans Tukey HSD( 0.05, Crosstab Report( 0 ), Connecting Letters Report( 0 ), Ordered Differences Report( 1 ) )}}} ), Where( Format( :gender ) == genlst[i] ), SendToReport( Dispatch( {"Response pain"}, "Effect Details", OutlineBox, {Close( 0 )} ) ); ) ) ); rfm = fm << Report; rfm[Outline Box( "LSMeans Differences Tukey HSD" )][4][1] << Make Combined Data Table;
I usually do
manually by right click on the table on the report and select Make Combined Data Table. The resultant data table follows the format as below
The values from the Where statement are not included in this combined data table. I then create new columns to fill in the missing information. Luckily, the ordering of the results is the same as the reports.
I don't know if this is the same issue or a separate problem that can be resolved with advanced scripting skills.
Derchieh
