automatic tables/update
☑ cool new feature
☑ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
As of v19, Tables/Update needs a lot of fine tuning:
Option 1:
duplicate columns will be added in addition to existing columns. Such columns have to be identified manually and removed afterwards.
If not, after a few updates a huge number of columns will accumulate.
Option2:
the user has to specify exactly which columns have to be added.
Maybe hundreds of columns ...
A fancy new automatic mode: "add non-existing columns" *)
JMP will compare the columns in the source table with the existing columns
- if a column exists, it is not added.
- if a column doesn't exist, it gets added.
  1. "add non-existing columnsin addition to none/all/selected:
  2. for "all", one could add a a checkbox:
    don't add duplicates of existing columns.
Why is this idea important?
Often a user wants to add information from another table via Tables/Update
- They don't want to add hundreds of duplicates of columns which are already there in the table.
- They don't want to invest a lot of time to decide column by column if the column is already available or if the column is new.
2 Comments
hogi
Level XIII
This graph shows how data tables get polluted by the current mode of Tables/update:
from Tables/Update changed!
