JMP Wish List
Time Profiler - Include ability to save how long code blocks take to run
We currently run a very long JSL script. We'd like the ability to save the time each line of code takes once the Time Profiler runs so we can use it to find speed improvements over time. Currently, we have to run every script with the Time Profiler & look for time differences by making a change & then re-running the Time Profiler
The ability to save the amount of time each line of code takes into a text file would be helpful to compare scripts over time. This way, there wouldn't be a need to re-run scripts when asked about a specific function or statement, the data would already be accessible.
Why is this idea important?
Data is constantly increasing & with it, scripts take longer to run. The ability to identify code blocks that are causing slowdowns are critical to maintain efficiency.
I'm currently using JMP 17.0.0.
2 Comments
Thank you for submitting this wish @Bagawandoss96! Your feedback is critical in helping us make JMP even better, and we are grateful you took the time to share your ideas. Your request has been documented and will be prioritized.
Level XIII
-> JSL Debugger.
