  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Tables join: option to update main table
☑ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2023
as we have a workaround for Tables/Update, this one is no longer needed
Tables/Join is a powerful tool to merge different data tables.
The only disadvantage: it generates a new data table instead of updating the main table.
I often have a table, with table dozens of table scripts which evolved over time - and Dashboards which refer to this table.
To widen the analysis, I want to add a column to the table - but Tables/Join generates a new table.
Please add an option in Tables/Join: Update main table.
If the option is enabled, the platform should update the main table instead of generating a new one.
If Jmp developers fear that Tables:Join gets too crowded by this option, they could hide the option behind a shift-click or invisible to other users.
Why is this idea important?
There is no fast way to merge new columns to a data table.
Table/Join is almost the perfect tool - but it generates a new table.
The additional setting will solve the issue.
15 Comments
hogi
Level XIII
cool!
Fuzzymerge for time + "Match columns" for some additional columns :)
hogi
Level XIII
@FN There is already a separate Wish for FuzzyMerge:
Add fuzzy join / asof merge / join by columns which do not have exact matches
... from 2022.
Unfortunately, the status was still "New" (Juliy 2023) - perhaps due to 0 Kudos up to now?
SamGardner
Level VII
