  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Symbolic Regression (=Genetic programming)
JMP has great visualization and pre-processing capabilities.
It will be nice to utilize these capabilities for the purpose of generating an explicit expression that is more versatile than polynomial approximation.
Some fields require explicit approximations rather than approximations generated via Machine Learning ("black-box"-type).  Quite often pure polynomial approximations are not enough.  Symbolic Regression can greatly help.
No initial specification of functional form is required.
https://en.wikipedia.org/wiki/Symbolic_regression
To have capabilities for Symbolic regression as a part of the Predictive Capabilities.
Why is this idea important?
Symbolic Regression significantly expands the polynomial regression capabilities.
It approaches the versatility of Neural Networks with advantage of providing explicit functional expression as a result.
3 Comments
Thank you for your wish. We will investigate further your request and come back to you.
Hello @VladimirB , an addin on Symbolic Regression is out here Symbolic Regression using Python Package. If you tried it, can you tell us if this fulfills your needs?
Status changed to: Delivered
