Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Build in confidence and prediction bounds in the Surface and Contour profilers and allow the user to toggle them off & on and to set the alpha values in a pane off to the side. You can use a different surface transparency on the surface profiler so you can still see the underlying shape of the prediction curve.
Would be great if the confidence and prediction intervals could be integrated into the projected contour plot underneath the surface profiler and connected to the Response Grid Slider. This is super useful in explaining how a response requirement i.e. the Grid Slider intersects the prediction surface. Would be super useful in explaining to project management when "it depends" whether or not a requirement is met.
