  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Summerize/Summary aggregation function for character data. Concat Charcter Vector into a Scalar (by)
Generalize the code to work with Summerize/Summary.
dt = current data table();
Summarize( g = By(:Column 0, :Column 1 ) );
For( i = 1, i <= N Items( g[1] ), i++,
   r = dt << Get Rows Where( dt:Column 0 == g[1][i] & dt:Column 1 == g[2][i]);
   dt:Column 3[r] = Concat Items( dt:Column 2[r], "_" );
nt = dt << Summary( Group( :Column 0, :Column 1, :Column 3 ) );
3 Comments
Ryan_Gilmore
Community Manager
Status changed to: Archived
hogi
Level XIII
very useful :)
Up to now, I used Split to sort the entries, combine them and merge them back to the main table:
Names Default to Here(1);
//-------- dt << new column ("rank", Formula( Col Rank( :name, :age ) )); // put names next to each other, grouped by age DTsplit=dt<< Split( Split By( :rank), Split( :name ), Group( :age ) ); // Combine columns to a linge column DTsplit << Combine Columns( columns( :"1"n, :"2"n, :"3"n, :"4"n, :"5"n, :"6"n, :"7"n, :"8"n, :"9"n, :"10"n, :"11"n, :"12"n ), Column Name( "allNames" ), Delimiter( "," ) );
//----- // Update data tables dt<< Update( With( DTsplit ), Match Columns( :age = :age ), Add Columns from Update Table( :allNames ), Replace Columns in Main Table( None ) );
to get:
If Summarize had an option to concatenate strings, the whole part between the //---- could be replaced by a simple Summarize.
hogi
Level XIII
