Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
In the menu Tables>Subset you can do "subset by a column", which is pretty much the same like "split by"
In Minitab you have the posibility to subset by formula, like in SQL, where column1 > 2 and column3<6 and genre=male and year>2016.
The only ways i know at the moment is to create a column with if then else formula in it or use the "JMP query Builder" for simple use Filters or create a new column under Available Columns" with the specific formula.
you could save 8-10 mouse clicks when there was an option in subset by formula...
