  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Stability Module 95% CI Automatically Applied Every Time Refresh
What inspired this wish list request? We often transfer graphs from the stability module to PPTs and reports - but whenever we update the data filter or change something that makes the graph reload, the 95% CI is reapplied no matter what preferences are applied.
What is the improvement you would like to see? Fix the bug and let us change it to no CI and keep it that way.
Why is this idea important?  This is a small bug that makes it harder to visualize data in certain circumstances and makes it harder to quickly use the graphs.
2 Comments
danschikore
Is this for the Degradation platform with the Show Curve Interval option?  It would be helpful to report the bug to Tech Support at https://www.jmp.com/support with additional details about the options in use and the preference settings.
Thank you @JNuhn for your request. We will investigate further this issue.
