  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
automatic tables/update
☑ cool new feature
☑ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
As of v19, Tables/Update needs a lot of fine tuning:
Option 1:
duplicate columns will be added in addition to existing columns. Such columns have to be identified manually and removed afterwards.
If not, after a few updates a huge number of columns will accumulate.
Option2:
the user has to specify exactly which columns have to be added.
Maybe hundreds of columns ...
A fancy new automatic mode: "add non-existing columns" *)
JMP will compare the columns in the source table with the existing columns
- if a column exists, it is not added.
- if a column doesn't exist, it gets added.
  1. "add non-existing columns" in addition to none/all/selected:
  2. for "all", one could add a a checkbox:
    don't add duplicates of existing columns.
Why is this idea important?
Often a user wants to add information from another table via Tables/Update
- They don't want to add hundreds of duplicates of columns which are already there in the table.
- They don't want to invest a lot of time to decide column by column if the column is already available or if the column is new.
2 Comments
hogi
Level XIII
This graph shows how data tables get polluted by the current mode of Tables/update:
from Tables/Update changed!
Sarah-Sylvestre
Level V
