  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Special (Reduced) Scheffe Cubic Model for Mixture Designs
JMP offers the "Scheffe Cubic" Model as standard model for design and analysis of Mixtures. It is known from literature the these model tends to overfit the data. The "Reduced Scheffe Cubic" or "Special Scheffe Cubic" ofte is the better choice. It would very useful to have the Reduced Scheffe Cubic model as standard choice in the user dialogues dealing with mixtrure problems.
See: https://bookdown.org/gerhard_krennrich/doe_and_optimization/
See https://community.jmp.com/t5/Discovery-Summit-2015/Efficient-Mixture-Process-Experiments-Using-Nonli...
6 Comments
Victor_G
Hi @Andreas_Büchse,
I might be missing something, but does the "Simplex Centroïd Design" option in the menu "DoE", "Classical", "Mixture Design" would answer your needs ?
It seems to do exactly what is mentioned in your links.
You can also specify the model yourself if you're using the "Custom Design" platform.
I hope this answer will help you,
Victor_G
Just a short comment to add an example of a Simplex Centroïd design case study I did: Use of Functional Data Explorer in a Mixture Design for Tribological Performance... - JMP User Commu...
Here is the design used (Simplex Centroïd design with K=3 and validation points to augment the design if necessary) :
Hope these answers will help you build your DoE with JMP :)
Andreas_Büchse
Level II
Dear @Victor_G ,
thanks for your comment. You are right, that the simplex centroid in the DOE Design Platfrom leads to design which you can model with the reduced Scheffe-Cubic model.
My point for the wishlist is more related to the custom designer and the list of models to fit to data you have. Especially when you have additional process factors and need to fit mixture-process-models.
Sarah-Sylvestre
Level V
Hi @Andreas_Büchse, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
mia_stephens
Status changed to: Not Planned For Now
Thank you for this suggestion. Goos & Jones outline two alternatives, and this would require some substantial research. We'll revisit as we begin planning for the next release.
