Simple way to copy and paste columns
There are many instances when I need to combine columns from different data tables into a new table. I know there are workarounds to do this (subsets, get script, etc), but why can't there be a simple copy column/paste column command?
Add copy/paste column commands to JSL
Why is this idea important?
Makes a common task very simple instead of resorting to more complex JSL workarounds.
6 Comments
hogi
Level XIII
you mean:
 << copy column as a synonym for << get script?
If  copy column(col)is fine for you [instead of dt << copy column(col)],
  you can create a wrapper for << get script:
Names Default to Here(1);
dt2 = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
dt << New Formula Column(
	Operation( Category( "Combine" ), "Ratio" ),
	Columns( :height, :weight )
copy column = Function({col},
	script = col << get script
paste column = Function({},
	script
copy column (Name Expr(Column("height/weight")));
Current data table(dt2);
paste column();
And via the GUI,  copy column / paste column is also available:
scott1588
Level IV
I'm looking for something that is as simple as the copy/paste column items in the GUI but for JSL.
Just dt << copy column (:name)
and
dt2 << paste column
no expr or any other JSL involved.
Maybe with a couple of position modifiers such as <after :colname>, <end>, etc.
scott1588
Level IV
Interestingly... there is a Copy Column command listed in the scripting index. But it has no information about it. I can't find it in the scripting guide.
But there is no Paste Column.
scott1588
Level IV
Another interesting variation of this might be to add modifiers to the New Table command to list columns to pull from other tables
New Table (dt1:colname, dt1:colname2, dt2:colname3)
This would create a New Table with the columns pulled from dt1 and dt2
Sarah-Sylvestre
Level V
hogi
Level XIII
Your function
looks like:
dt1 << Subset(All rows,	Selected columns only( 0 ),	columns( :colname, :colname2, :colname3));
