  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
subst() - substitute() 2.0
☐ cool new feature
☐ could help many users!
☑ removes something that feels like a „bug“
☑ nice to have
☐ nobody needs it
Substitute is a very powerful function for expression handling:
A big disadvantage of Substitute: it evaluates it's arguments : (
Therefore, Expressions with Substitute() get quite lengthy and hard to read. Besides that, a new JSL scripter has to learn the correct syntax - nobody expects that all those Expr() are necessary.
Example:
Substitute( Expr( a + Sqrt( a ) ), Expr( a ), Expr( b ) )
A new function subst () which doesn't evaluate it's arguments. Then one can write :
Substitute( a + Sqrt( a ), a, b )
Why is this idea important?
Subst() and Eval(Subst()) will be used millions of times - and each time a JSL scripter will be happy that you implemented it!
3 Comments
hogi
Level XIII
In most of the cases, the user will provide at least one of the arguments as a name -  with the idea that JMP looks up the name and uses the Name Expr instead of the name itself.
So, JMP should evaluate the arguments to a level (look up, take the Name Expr if available, don't evaluate further) where it's possible to write:
a=Expr(myExpr);
Subst(x+y, x, a) // result: myExpr + y
instead of
a=Expr(myExpr);
Substitute(Expr(x+y), Expr(x), Name Expr(a)) // result: myExpr + y
And if a user wants to be sure that JMP uses the argument as it is (without resolving the  Name Expr.), he can write:
a=Expr(myExpr);
Subst(x+y, x, Expr(a)) // result: a + y
hogi
Level XIII
With other words:
 Subst()
... a Substitute() with the magic/easiness of Extract Expr()
clear symbols();
// direct mode, no Expr necessary
Extract Expr(x + y, x);// -> x
Extract Expr(x^2 + y, c);// no c in x^2 + y ->  empty
// Name Expr mode
c=Expr(x^2);
Extract Expr(x^2 + y , c);// looks up c = x^2, find "x^2"" in x^2 +y
unfortunately, what doesn't work (as easy as I wished):
c=Expr(x^2);
Extract Expr(c * d, Expr(c))
Extract Expr
mia_stephens
Thank you for the suggestion @hogi .
