I would like an option in the Distribution Platform Preferences to set standard values for Confidence and Proportion to Cover to be used in Tolerance Interval Calculation.
Similarly, when computing Tolerance Intervals for many by-groups, it would be great if there was an option to specify Confidence and Proportion to Cover only once for all by-groups, because typically in such a situation I want to use the same levels for all groups (or is there a way to this by holding down a key or sth? Using ctrl works only to the degree that the interval is computed for all groups, but each time levels must be specified).
Maybe you can supply typical settings as you do for Confidence Intervals, although here it would have to be 3x3 (0.9/0.9, 0.9/0.95, 0.9/0.99, 0.95/0.9, .... ) plus other...
