Searching elements in a listbox (JSL)
When we have a listbox into a UI in jsl we cannot search elements easily into it (it's only possible with filter col selector whch is adapted to data table columns only) . A code has been proposed to do that in the community but it's difficult to make a generic solution. For a window containing several listboxes, it doesn't work properly.
An argument << Show Filter into the listbox() object should be great.
Why is this idea important?
Many users have the same problem, hard to select the good element when there are lots of elements.
1 Comment
hogi
Level XIII
A Combo Box with setting editable might be what you want:
New window("test", Combo Box( {"Germany", "France","Italy"}, editable))
