Script Editor improvements when using Python (add opionated formatter, dark theme, auto-match single-quotes, properly highlight (mis)matching brackets)
Working a little with Python code in JMP's Script Editor and hoping for a bit more.
Add dark theme (Currently there isn't properly working dark theme and I had to create my own). Make this different from JSL so it is immediately obvious which editor is open (background might be most important part of this).
Bracket highlighting doesn't seem to work properly with Python in Script Editor.
When using single-quotes they aren't being auto-matched
Add some sort of opinionated formatter for Python (ruff, black, ...) which could be used with Reformat Script
Disable JSL auto-complete from Script Editor when using Python (or add one which supports Python).
Why is this idea important?
Makes writing Python in Script Editor easier and more fun. Currently I almost feel like I should always go to some other IDE and paste the code back to Script Editor.
2 Comments
Sarah-Sylvestre
Level V
Sarah-Sylvestre
Level V
Status changed to: Under Consideration
Hello! You first 3 listed requests (dark theme, highlighting, auto-match), will be available in JMP 19. The last two requests are under consideration.
