  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Save confidence and prediction interval formulas directly from the generalised regression platform
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case.
In the least squares platform, there is the possibility to directly save the prediction formula + confidence interval formulas + prediction interval formulas, with just one click (see screenshot). When variable selection is important, we work in the generalized regression platform. From there it is sadly not possible to directly save the prediction formula + confidence interval formulas + prediction interval formulas (see screenshot). Instead, the model has to be refit after model selection in the least square platform to get this benefit, which is also not possible if you choose a different response distribution than normal.
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see.
I would like to see the same functionality for saving prediction formula + confidence interval formulas + prediction interval formulas with just one click in the generalized regression platform.
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).
This functionality would be likely easy to implement, save clicks, and make life a lot easier for everyone performing model selection concerned with model uncertainty.
1 Comment
Sarah-Sylvestre
Level V
Thank you for sharing this request!
