%3CLINGO-SUB%20id%3D%22lingo-sub-404118%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ESchaltfl%C3%A4che%20%E2%80%9EReihenfolge%20umkehren%E2%80%9C%20in%20den%20Legendeneinstellungen%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-404118%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CP%3EDies%20w%C3%A4re%20eine%20kleine%20Verbesserung%20der%20Benutzerfreundlichkeit%2C%20aber%20die%20Legende%20eines%20gestapelten%20Balkendiagramms%20ist%20immer%20in%20der%20umgekehrten%20Reihenfolge%2C%20als%20man%20es%20intuitiv%20erwarten%20w%C3%BCrde%2C%20wenn%20man%20von%20oben%20nach%20unten%20scannt%20(das%20oberste%20Element%20in%20der%20Legende%20ist%20das%20unterste%20Element%20im%20gestapelten%20Balken).%20Sollte%20sich%20das%20nicht%20%C3%A4ndern%2C%20w%C3%A4re%20eine%20Schaltfl%C3%A4che%20zum%20Umkehren%20der%20Reihenfolge%20in%20den%20Legendeneinstellungen%20w%C3%BCnschenswert%2C%20%C3%A4hnlich%20der%2C%20die%20beim%20%C3%84ndern%20der%20Wertereihenfolge%20einer%20Spalte%20verf%C3%BCgbar%20ist.%3C%2FP%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-404118%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3EMassenanpassung%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E
Reverse order button in legend settings
This would fall under a small "quality of life" improvement but the legend for a stacked bar chart is always in the opposite order of what one would intuitively expect when going scanning from top to bottom (the top item in the legend is the bottom item in the stacked bar) . If that isn't changed it would be nice to have a "reverse" order button in the legend settings box, similar to what is available when changing the Value Ordering property for a column.
7 Comments
hogi
Level XIII
Thumbs up from my side!
Bar Chart: value order?
hogi
Level XIII
For comparison: Value Order has a functionality to reverse the order:
hogi
Level XIII
hogi
Level XIII
@Sarah-Sylvestre  - wish from 2021.
very helpful - close to zero effort to get implemented.
the benefit: nobody in the audience has to turn the head anymore (or the eyes? - or one eye) to align the legend to the plot
shampton82
Level VII
@hogi and @Sarah-Sylvestre
Yes please, this would be so helpful!!
Steve
hogi
Level XIII
These are the things which make JMP so unique:
ultra-tiny but super useful!
the user can stay in the flow, JMP provides a one-click solution which saves the user from adjusting settings manually by dozens of clicks.
Thank you everyone for showing your support of this wish!
