When I tried to join more than 10 data tables at once using Query Builder, I noticed that there is currently no way to freely change the order in which the data tables are joined.
I would like to be able to freely change the order of the secondary tables when joining multiple tables in Query Builder.
This could be implemented either through a simple click-and-drag operation or through command buttons for changing the table order.
Why is this idea important?
This improvement would enhance usability and make the workflow more efficient.
Currently, after joining multiple tables, I manually rearrange the columns into the desired order. If the order of the tables could be specified before performing the join, the resulting columns could be arranged accordingly, eliminating the need to manually reorder them afterward.
This would be particularly helpful when working with a large number of tables and would significantly reduce repetitive manual work.
