What inspired this wish list request? Current preferences in JMP for the DOE platform allow for setting a maximum Design Search Time. Similarly, I'd like to set a fixed Number of Starts as the default of '1' may not be sufficient.
What is the improvement you would like to see? Add an option in JMP Preferences to fix the value for 'Number of Starts'.
Why is this idea important? The coordinate-exchange algorithm used for more complex scenarios benefit from having hundreds, or perhaps thousands of starts to robustly choose a good run sheet. Folks can use Custom Design and perhaps be tricked into thinking a design setup is poor but may benefit simply by trying many designs and getting the best one. Setting a default minimum protects against this phenomenon. If run times are excessive, the user can always cancel due to slow progress and rerun with fewer starts.
It is possible that if 'Design Search Time' and 'Number of Starts' are in conflict for one another if both are set as preferences. In this case, you may let the Design Search Time take the priority (example - 1000 starts are fixed, but a search time of 300 seconds is set; it may only be able to evaluate 235 designs in 300 seconds, so it would cut off at that case since 1000 would be well beyond that limit).
