Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
I would like to have an interface which I could use to check different relations between different datatables and reports generated from them. This would help user to track how different data tables and visualisations might be related and possibly also help to visualise the flow needed to reach the end. Of course it would be nice to able to also something from this interface (bring table / table to top for example). This would require JMP to save the relations somewhere, so this should maybe be an option in Preferences.
Some example ideas (most likely there are way better visualizations for this):
Lazyu example script for parallel and ishikawa. Using something like this would work, but you would have to have your own functions/class to handle subsetting and so on, to get all references. You can also parse some names and link them back (subset and summary).
