Reference other data tables in JMP Live Refresh Scripts
My group has a JMP Live data table that refreshes daily using a refresh script. This script uses PI tags to pull data from our PI servers. Currently all of the tags (roughly 500 of them) are in a list at the beginning of the refresh script that is used to make the data pull. In addition to the tags themselves, there are also lists with information about the tags (Name, pull method, grouping information, etc).
Because of the list format, it is incredibly cumbersome to add or modify tags and it is also more prone to error. It would be nice if there was another table hosted in JMP Live that had all of the tag data we currently have stored in lists. We could then reference this table in our main data table's refresh script to get all the information we need. This would reduce the size and complication of our script and allow us to have a centralized list of tags.
The ability to reference other data tables that are hosted in JMP Live from a JMP Live refresh script
Why is this idea important?
It would allow for streamlined refresh scripts as well as a level of interactivity between JMP Live data tables.
5 Comments
dieterpisot
Status changed to: Under Consideration
dieterpisot
Sarah-Sylvestre
Level V
Status changed to: Delivered
Gabe_Nelson
Level II
I saw you changed the status of this to delivered! Would you mind giving an example of the JSL syntax you would use to reference another data table within a JMP live refresh script?
Ryan_Gilmore
Community Manager
Hi @Gabe_Nelson , if the data table is listed in the "Referenceable data tables" section, you can reference the data table by name, e.g.
tagsDt = data table("PI_Tags");
then use tagsDt throughout the remainder of the script. You will need to use the name of the file and not the title.
