Provide an option to data filter to make it filter on button press (add new optional Run button)
I have come across few types of issues with data filters when working with large datasets which make filtering data very slow and unresponsive (conditional data filters getting unfiltered and using Find). Issues with Find can be related to few (bugs? or features) how Find works with local data filters, but Run would still be nice option to have.
I would like to see an option in Filter red triangle menu to create Run button for a filter. This would allow me to filter the data to the level I want to before filtering it all.
Why is this idea important?
Using filters with data having a lot of data can get quite unresponsive from time to time, especially if there is any calculations involved.
10 Comments
hogi
Level XIII
This feature could help - especially when you want to select several entries in a filter.
Often, I select the first item, press SHIFT or CTRL - and when I select the second item, Jmp just selects the second item - because the background actions are still running which were triggered by selecting the first entry.
solutions:
- take care and wait long enough
- it seems to help if you start by selecting an item with few corresponding rows (then you don't have to wait for so long till it's possible to select the second item)
FN
Level VI
This is a common limitation with process and manufacturing data indeed.
JMP has something similar implemented already when using a filter within predictor screening.
There is an option to re-run the analysis only on demand.
hogi
Level XIII
another application case: a large data set and character data to filter. When I use the filter on top of the data filter and write a word, with every character JMP freezes for some while till the next character can be entered. This is so frustrating that I even added a text edit box to key in the whole word  - which can then be copied and pasted to the actual data filter.
hogi
Level XIII
the optional "filter on button press" could be analogous to what's possible in JMP Live (with auto-update didabled):
hogi
Level XIII
the most kudoed "new" wish
hogi
Level XIII
There is a new winner:
Hi all, thank you for taking the time to provide feedback on this request! Your input is greatly appreciated. This request has been forwarded to our development team and is currently under review. I will share any potential updates here.
hogi
Level XIII
In general, it's great that the action is immediate:
the user selects entries and the report gets adjusted.
For some special cases (esp: large data sets) an option to disable the automatic update will help.
matth1
Level IV
Although this wish list item has not been implemented in JMP 19, the response speed of the data filter list box when entering a search string has been massively improved. Now, even for a huge number of entries in the data filter window (I'm playing with >22k entries), the list is filtered instantly as I type each character, with no lag or missed entries. This is a great optimisation for my use case.
shampton82
Level VII
@Sarah-Sylvestre and @hogi Another way this would be great is when using the Predictor Screener.  Each time you change the filter it re-calculates the screener, so if you try and change multiple items you have to wait through the re-calculation after each click.  Very annoying!
