Presenting actual number of observations for each LSMean in Fit Model
In Fit Model reports, show next to each LS Mean, the actual number of observations used to calculate it (as the "Number" next to each mean in "Fit y by X"). This information is especially important when the model is re-analyzed (often several times) after suspected outlier data point(s) is/are excluded or un-excluded.
1 Comment
