Plotting several trends from sensor data that have different units (or scale)
The GraphBuilder can be used to visualize sensor data as Y's and a DateTime as X to make trends.
However, when Y's have different units or scales, the only way is to pre-standardize the columns and plot them all together.
An axis default option that allows this visualization without having to transform the columns will be very essential for new JMP users that are getting data from their manufacturing systems (e.g., Osisoft PI in JMP 17).
See how it is done in historians below (+video).
To be clear, this is already standard in JMP, but only if you put variables in one axis:
Again, the moment you add an X variable (DateTime), the plot squeezes variables using only one scale.
16 Comments
ih
Super User (Alumni)
Super User (Alumni)
Awesome news!
Steve_Kim
Level IV
Many thanks! Keep up the good work! : )
hogi
Level XIII
candidate of the Wish List Prioritization Survey - pilot run:
Introducing the JMP Wish List Prioritization Survey!
Sarah-Sylvestre
Level V
Hello everyone! If you are an authorized user of JMP 18 and would like to give this a try in the latest beta release, you can join our Early Adopter program - go to jmp.com/earlyadopter, if you are not already a part of it. Check out JMP 19 EA3: Parallel Y Axes in Graph Builder and be sure to let us know what you think.
Sarah-Sylvestre
Level V
Sarah-Sylvestre
Level V
Status changed to: Delivered
