Please provide preferences for tables menu
There seems to be no possibility to adjust settings for the tables menu in the preferences. In particular, for the table>summary function, the box "Remove excluded groups" is always unchecked, and - newly in JMP18 - the output table name is preset as "Summary of ...". (this leads to an error if you take another data table and use the "Recall" button - the resulting summary table will then get a wrong name!)
I cannot find a way to change these presettings and it's annoying to always change them manually.
I'd like to see the different options for the tables menu similar to the "preferences" menu for the platforms. All the options which can be manually checked/unchecked in the tables operations should be available for preference settings,
Why is this idea important?
In order to avoid lots of annoying manual adjustions (and avoid errors like the one mentioned above)
3 Comments
hogi
Level XIII
Another setting I would like to be able to change in the preferences:
Axis/Tick labels/ Long Divider
So, maybe extend the Wish to:
Provide an option to specify DEFAULT settings - not just for platforms in the Tables menu.
@Community: please tell us which settings you want to specify via the preferences.
Sarah-Sylvestre
Level V
Thank you for sharing this request; we value your feedback!
Nilsson
Level I
This update would be very important for me. I just realised the problem with the recall button reusing the previous name of the output table, and wonder how many files I might have given the wrong name and misinterpreded because of this.
