We want to hear your ideas for improving JMP software.
  1. Search: Please search for an existing idea first before submitting a new idea.
  2. Submit: Post your new idea using the Suggest an Idea button. Please submit one actionable idea per post rather than a single post with multiple ideas.
  3. Kudo & Comment Kudo ideas you like, and comment to add to an idea.
  4. Subscribe: Follow the status of ideas you like. Refer to status definitions to understand where an idea is in its lifecycle. (You are automatically subscribed to ideas you've submitted or commented on.)
We consider several factors when looking for what ideas to add to JMP. This includes what will have the greatest benefit to our customers based on scope, needs and current resources. Product ideas help us decide what features to work on next. Additionally, we often look to ideas for inspiration on how to add value to developments already in our pipeline or enhancements to new or existing features.
Paste multiple column names directly in column dialog filter
Topic: add build-in capability that allows to paste directly a list of column names -from clipboard- in column dialog filter.
Today's workaround: as of today, I did a script that  takes the clipboard content -loaded with column names- and converts it into a regular expression. Then, I paste this regular expression in filter and I select 'regular expression' filter mode. This works but is a bit painful.
I use this often when working with 'column switcher', but I assume this may work for many other needs.
3 Comments
gzmorgan0
Super User (Alumni)
It might be useful to understand the source of the list of column names and your usage/expectations:
  • Is the list a comma delimited string (assuming no commas in the column names?
  • Will each name have double quotes?
  • Will the list be enclosed with braces?
  • Is the list source from say a user selection from one JMP table or some external source like email or other external document?
  • Will the names be a perfect match, case sensitive?
From experience, more details about the scope and usage helps JMP developers scope the size and importance of your request.
damien
Level II
For my personal use, I use names without double quotes nor braces.
Delimiters might either be comma, space, tab, or feed carriage.
List source may come either from JMP or Excel.
And I use perfect match.
Please find below the script I wrote (I used Python call for special characters replacement as JMP script is painful when handling "["):
Input = list in window's buffer
Output = regular expression in window's buffer (then, I paste it into JMP's filter and select 'regular expression' mode)
//RAMIS - 2021
Names Default To Here( 1 );
//Get clipboard
data = Get Clipboard();
//split list into array
testList_raw = Words( data, " \!t\!n\!r," );
//keep only unique entries
myArray_set = Associative Array( testList_raw );
unique_myArray = myArray_set << Get Keys;
//replace special characters
Python Init();
Python Send( unique_myArray );
Python Submit(
myList =unique_myArray
myOutput = ','.join(myList)
myOutput = myOutput.replace("[","\\[")
myOutput = myOutput.replace("]","\\]")
myOutput = myOutput.replace(",","|")
Wait( 0 );
//output to window's clipboard
myClipboard = Python Get( myOutput );
Set Clipboard( myClipboard );
Regards,
Damien RAMIS - NXP
Hi @damien, thank you for your suggestion! We have captured your request and will take it under consideration.
