  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
PI Server AF connector improvements
The PI/AVEVA connector is substantially improved, enabling JMP to be used in manufacturing datasets.
PI AF databases have multiple elements. The window to select Attributes cannot be resized properly.
In addition, we need to be able to search the data using a bar to filter elements.
Last but not least, users should be able to copy and paste the selection done in a previous moment, so the work does not need to be repeated.
Similarly, keeping the previous options in memory will help with new extractions (or by having a recall button)
8 Comments
Sarah-Sylvestre
Level V
FN
Level VI
Any update on this wish, @Sarah-Sylvestre ?
Thank you.
Sarah-Sylvestre
Level V
Hello! No updates at this time but this is on our radar and has been communicated to development.
FN
Level VI
Great. The hard job is done already.
Hopefully, the UI/UX improvements can be prioritized, making JMP the perfect companion for PI historians.
FN
Level VI
After some more tests:
- Update doesn't add new rows. Instead, downloads the whole period again (duplicating values in the main table).
- Once the data is extracted, the script change attribute did not working either
- It will be nice to extract both server time and UTC (having two columns in the table)
Sarah-Sylvestre
Level V
Thank you for the additional feedback!
FN
Level VI
Hello Sarah, any further updates? Thanks
Sarah-Sylvestre
Level V
Hi, we currently don't have any further updates. I will update this request if there are any changes. Your feedback has already been shared with the development team.
