I would like for JMP to be able to open Apache Parquet files and handle them in the same way that HDF5, JSON etc...can be handled. Thanks a million.
@MassimoMartucci The Apache Parquet file importer link is not working for me (says "Access Denied"). Can you re-post it, or share somehow?
Thank You very much!
@ts2 That add-in is not updated anymore. Please refer to the most recent add-in in the JMP Marketplace: 'Can Open-er' File Importer
@MassimoMartucci Thanks for responding. :)
Unfortunately I am required to use JMP 17.2, so the Can Open-er won't work for me.
No worries, I completely understand not supporting or distributing deprecated code.
