Opening JMP file stored in local company network
When opening a JMP file (located on a shared folder in a company local network), JMP is copying it locally and opening it, modifications are only local until file is saved.
But if in the meantime, the same file is open and modified by another user, some modificaitons can be lost.
A message box informing that the file is yet opened by someone else can be very useful, or at least informing the user that you have to be careful with shared files.
May be a lock information can be added to the JMP files ?
Why is this idea important?
Important because I experienced this situation and it is always annoying to discover that we have lost data or analyses!
1 Comment
hogi
Level XIII
I see the same issue with files stored on OneDrive/Sharepoint.
Multiple users can work on the file. But changes get lost (or the file is stored with an appendix) if another user changed the file in the meantime:
Optimize Sharepoint Integration
huge issue!
