  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
One-sided limit option in Fit Life by X Custom Estimation (which exists in Life Distribution)
In Life Distribution Custom Estimation, Confidence Limits can be two-sided, one-sided upper or one-sided lower. In Fit Life by X I'm missing this option - confidence limits are always two-sided. It would be great to have one-sided limits in Fit Life by X as well.
Below are screenshots from Life Distribution (top) where e.g. "Lower" can be selected via the red triangle and Fit Life by X (bottom). I suppose there I could choose a confidence level 90% two-sided to obtain a 95% one-sided lower limit, but this can easily be misunderstood in reporting. I generally wonder if "one-sided" resp. "two-sided" should appear in the column title, or if an extra column could provide the info on Interval Type - "one-sided" or "two-sided", as at the moment this aspect is clear only through the fact that one column is missing when calculating one-sided limits in Life Distribution.
LifeDistribution_CustomEstimation_Interval.JPG   LifebyX_CustomEstimation_Interval.JPG
