New filter "Column Filter" a combination of Local Data Filter and Column Switcher
Depending what you are doing in JMP, you sometimes have to unnecessarily move from wide data to tall data due to how column switcher / local data filter work - we cannot "filter" columns currently. This is one of the reasons why I did create Enhanced Sankey Plot (ESP) add-in as it is fairly difficult to quickly add/remove specific columns from graph builder.
I would like to have new tool? "Column Filter" which would allow me to determine which columns I want to show. This would function basically like Data Filter but for columns.
If I have a situation like this where I have multiple columns in my Y-axis for example
I don't have any easy options to hide or add extra columns. If I want to some of those columns or add new ones, I have to stack the data first and the create a graph with local data filter
This does work great but sometimes this feels very unnecessary step.
Why is this idea important?
This would make the gap between tall/stacked and wide/split data smaller.
3 Comments
jthi
Script to demonstrate how this could work (this is very far from usable product, but should function as demonstration, I also will turn this into add-in/toolbar when I have enough time to properly design the UI)
One column at Y
Add more and refresh
Remove X role
Add two to X role
View more...
Names Default To Here(1);
delete_variable_for_role = function({report, role}, {Default Local},
	all_variables = report << get variables;
	For Each({variable}, all_variables,
		colname = Arg(variable, 1) << get name;
		Try(
			Eval(EvalExpr(
				report << Remove Variable({Expr(NameExpr(AsColumn(colname))), Role(Expr(role)), Position(1)})
add_variables_for_role = function({report, columns, role}, {Default Local},
	For Each({colname}, columns,
		Eval(EvalExpr(
			report << Add Variable({Expr(NameExpr(AsColumn(colname))), Role(Expr(role)), Position(1)});
update_cols = Expr(
	cur_cols = fcs << get selected;
	cur_role = cb << get selected;
	report << inval;
	delete_variable_for_role(report, cur_role);
	add_variables_for_role(report, cur_cols, cur_role);
	report << update window;
	wait(0);
prepend_column_filter = Expr(
	lb = (Report(report) << top parent) << child;
	lb << Set Horizontal(1);
	ob_colfilter = Outline Box("Column Filter",
		V List Box(
			H List Box(
				Panel Box("Role to Filter",
					Lineup Box(N Col(1),
						Text Box("Select Role to filter"),
						cb = Combo Box({"Y", "X"})
				Panel Box("Actions",
						Button Box("Refresh",
							update_cols
			Panel Box("Columns",
				fcs = Filter Col Selector(Datatable(dt))
	cur_height = report << get height;
	fcs << set height(cur_height - 200);
	fcs << set width(200);
	Eval(EvalExpr(
		ob_colfilter << Set Menu Script(
			{"Remove Column Filter", Expr(ob_colfilter) << Delete Box; Expr(lb) << Set Horizontal(0)}
	lb << Prepend(ob_colfilter);
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
dt << Ungroup Columns;
report = dt << Graph Builder(
	Size(528, 653),
	Show Control Panel(0),
	Fit to Window("On"),
	Variables(X(:SITE), Y(:NPN1), Y(:PNP1, Position(1))),
	Elements(Boxplot(X, Y(1), Y(2), Legend(4)))
wait(2);
prepend_column_filter;
jthi
hogi
Level XIII
wonderful idea!
soooo useful, thanks @jthi
