  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Multi File import: add a fast mode
☐ cool new feature
☑ could help many users!
☑ feels like a bug
☐ nice to have
☐ nobody needs it
Multi file Import: Discovering Files takes too long
For files which are stored in a network folder, it's can be faster to open Python, write a new code using GLOB and use the file list as input for Open in a for loop
... than to wait for MFI to fill the file list with entries which are then de-selected by the name filter.
Please add an Option to MFI which i as fast as GLOB:
The user specifies some filenames -> MFI finds the files (if the specs for data, size etc. are disable, there is no need to invest minutes to get this data. get it when the user activates one of the specs)
And Don't do it vice versa:
find all files in the specified directory, read the date, file size, etc. and then find out that just 2 of the thousand of files in the list match the filename spec.
Why is this idea important?
Make Jmp as fast as other tools.
6 Comments
hogi
Level XIII
Jmp 18 will have an option to select files manually:
... preventing Jmp from
... and
time to run the same script:
Jmp 17: 37s till add data is loaded
Jmp 18: 7s
hogi
Level XIII
Thanks you sooo much, such a speed improvement:
  1. Pick Files via FilePicker -> use
  2. run MFI with <<Set Use File List( 1 )
hogi
Level XIII
@Sarah-Sylvestre . Thanks for implementing this feature in Jmp18.
-> delivered :)
Sarah-Sylvestre
Level V
Status changed to: Delivered
shampton82
Level VII
This is great!!  Thanks JMP team! (and great suggestion @hogi )
hogi
Level XIII
