Moving the distribution calculator under the calculator heading rather than "Interactive Teaching Scripts" would make the categories more consistent.
Hi @TriangularCat94, thank you for your suggestion! We have captured your request and will take it under consideration.
@TriangularCat94 you can download this add-in https://community.jmp.com/t5/JMP-Add-Ins/Student-Add-In/ta-p/441699 which will create a new "Student" menu in the JMP Main Menu which has links to all of the calculator scripts. Does that meet your needs?
@TriangularCat94 after some further investigation, I learned that we are planning on providing links to the calculator scripts in both the Interactive Teaching area and the Calculators area in the sample index.
Wonderful! Thank you!
