Measurement uncertainty
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case.
Variability/Attribute Gauge Chart:
A suggestion for this platform: adding in the output the standard deviation of the measurement system called “Measurement Uncertainty” in metrology
This is just the square root of Gauge R&R Var Component
And may be the extended uncertainty which is the square root of Gauge R&R Var Component multiplied by the quantile for xx% confidence
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).
because it is a metrology standard and for the moment the user needs to calculate the square root of the variance
1 Comment
Joyce_Pan
Level II
I second that!
