  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Manual axis labels are 'mixed up' when plotting multiple columns
The problem occurs in the following situation: When you plot various parameters/columns and rename one or more axis labels, the renamed axis label is tied to the position of the parameter on the graph and not to the parameter itself. For example, you can plot columns A, B, and C on the y-axis. Then rename the axis label of column A from "A" to "New label A". If you now insert a new column D above A, the axis labels will be: "New Label A", "A", "B", "C". So "D" will be directly labeled "New Label A", but in reality we only wanted to rename "A" to "New Label A". In some cases, this behavior can cause a lot of confusion.
When an axis label is changed, the change should be associated with the parameter/column, not just the chart position. Sometimes you want to change the order of the parameters in the chart and of course the change of the axis label should also change its positions accordingly.
Why is this idea important?
This problem seems to be a bug and should be fixed since the behavior of JMP is unexpected. Wrong labels can cause a lot of confusion.
18 Comments
hogi
Level XIII
@mia_stephens
the current beta version of JMP19 deletes some of the manually changed labels.
A test data set to check if it's working as expected:
The plot should show the counts of the students 2x.
a) as percent. labelled "percent"
b) as counts, labelled "# student"
After saving and reopening the script, the graph should still look like this:
Names Default to Here(1);
Graph Builder(
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables( X( :age ), Y( :height ), Y( :height ), Overlay( :sex ) ),
	Elements(
		Position( 1, 1 ),
		Bar(
			X,
			Y,
			Legend( 1 ),
			Bar Style( "Stacked" ),
			Summary Statistic( "% of Factor" )
	Elements(
		Position( 1, 2 ),
		Bar( X, Y, Legend( 2 ), Bar Style( "Stacked" ), Summary Statistic( "N" ) )
	SendToReport(
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "percent" )} ),
		Dispatch( {}, "Y 1 title", TextEditBox, {Set Text( "students" )} )
hogi
Level XIII
with the option disabled,
the generted code looks like this:
mia_stephens
Hi @hogi , have you reported this to [email protected] (so that beta feedback is captured)? Thanks!
hogi
Level XIII
Hi @mia_stephens , yes I did.
Same issue in EA3.
hogi
Level XIII
Hi @mia_stephens , we discussed the issue at the DACH User Group Treffen 2024 am 7./8. Oktober in Ingelheim .
Besides fixing the issue, please also provide a way to apply the changes simultaneously for multiple plot:
e.g. via
 :folded_hands: Column Property: Column Name Alias / Allow secondary or alternate column names
For Tick Labels, (with JMP17 ?) a cool functionality was introduced:
when the user clicks for some time on a tick label, a special edit mode is activated - and the changes are saved as Column Property: Value Labels
[very cool functionality, very well hidden - how many users know it?]
parallel approach for Axis Labels:
when the user clicks for some time on an axis label, a special edit mode is activated - and the changes are saved as Column Property: Column Name Alias.
As an alternative: right click menu - > save as column name alias.
Maybe:
Column Name Alias could provide a list of values,
(e.g. for different languages, different types of plots)
In a graph, the user can select "use column name alias" with an index.
(view in My Videos)
hogi
Level XIII
hogi
Level XIII
Sarah-Sylvestre
Level V
Status changed to: Delivered
