  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Making JMP Exporting Figures Visually appealing and Editable
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case. Data is typically presented via PowerPoint presentation. Graphpad Prism is the standard for generating figures because they are both visually appealing and they are editable once embedded in a PowerPoint presentation. As much as I like JMP, I often need to present the results via Graphpad Prism figures to meet the needs of my audience.
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see. I would like an option to embed figures into PowerPoint in such a way that they can be edited. If this is not possible, I would like the figure visuals to be reworked in JMP to be more appealing for presentations. I am open to alternatives that would make the data more accessible and visually appealing via PowerPoint.
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).These changes would make other more willing to switch from Graphpad Prism to JMP. This would benefit users by giving them the functionally of JMP without having to compromise their presentations or data accessibility.
3 Comments
SarahGilyard
Thank you for posting RyanShirey. This request is related to an internal project we have recently began exploring to improve exporting JMP output to Powerpoint. We are in the very initial stages of scoping this project but we may reach out to you for your input when we get further along. Thanks!
hogi
Level XIII
@RyanShirey , you can copy graphs as enhanced metafile / EMF and paste them into Powerpoint.
This allows you to edit the plot - add shadows, change text, change colors ...
(view in My Videos)
