Make it easier to get results from reports via JSL
Status:
We like it! (in the queue)
Submitted by
ih
on
11-08-2021
08:12 AM
There are a lot of forum posts about how to get results from reports. This could be made easier by adding some attributes to the display tree and defining two new functions that would do most of the work for the user. I propose this syntax:
platform = Fit Model( ... );
platform << Get Result( "BIC", fit("NormalLassoAICValidation") );
//returns [0.683248]
Display Tree Attributes
- Define a set of result types that is standard across all platforms. This will be a big list, but if two platform both report an adjusted R2, they should both use the same result type.
- Add the result type to an attribute in the display tree for the column, cell, and/or anywhere else it is displayed, similar to the helpKey attribute for some platform outlineboxes.
- Display the result type somewhere in the platform GUI, maybe in a hover label for everywhere it is displayed
- Do something similar to flag outline boxes containing a fit created by the model (think '...fit with 6 components' in PLS or 'Normal Lasso with AICc Validation'). Here the attribute would be specific to the platform.
Functions
- Create functions to get
- The result values
- The report element containing the result
- The report element of the fit
- The scriptable object of a fit
- Call them like this
platform << Get Result("AdjustedRSquared") //Matrix or list of all Adjusted R Squared values platform << Get Result("AdjustedRSquared", fit("NIPALS_1")) //Matrix or list of all Adjusted R Squared values in fits with NIPALS_1 platform << Get Result("AdjustedRSquared", fit("NIPALS_1"), fitnumber(1)) // Matrix or list of all Adjusted R Squared values in the first fit with NIPALS_1, should be exactly one value platform << Get Fit("NIPALS_1") //returns the scriptable object platform << Get Fit("NIPALS_1","object") //same platform << Get Fit("NormalLassoAICValidation","report",fitnumber(1)) //returns the report from the first fit with NormalLassoAICValidation
- These functions these could be variations of wrappers around XPath:
platform << XPath("//NumberColBoxItem[@ResultType='AdjustedRSquared']") platform << XPath("//OutlineBox[@Fit='NIPALS_1']") platform << XPath("//OutlineBox[@Fit='NIPALS_1']") << Get Scriptable Object fm << XPath("//OutlineBox[@fit='NIPALS_1']//NumberColBoxItem[@ResultType='AdjustedRSquared']")
10 Comments
