Make adding and removing group by columns from quick formulas more intuitive
Removing all columns from quick columns can be unintuitive. Let's say you pick two columns to group by but then you wish to remove those. You will have to select EXACTLY those two columns to clear group by -> if you select any more those will be added to group by, if you select all columns old ones will be removed and new ones added. So you end up in this cycle where you are continuously right clicking on separate columns and checking which columns are still in group by.
I would like to see few possible changes.
1. Add new option "Clear Group By". This would remove all columns from the group by
2. Figure out how to make adding/removing columns more intuitive (add new buttons Add to Group, Remove From Group? instead of just having a toggle). Example follows:
I have Semiconductor Capability table open and I wish to create grouping column. First I think I need to have lot_id and wafer as my group columns, I select then and make them into the group. Then I remember that I have to include SITE to my group. I still have my lot_id and wafer selected so I just add SITE to selection and click group by
What I will end up with is just SITE in the group
And it can get even messier when you try to add more columns and finally try to clear them...
Why is this idea important?
JMP is interactive tool and it should be easy to use as possible. Currently it feels like it is easier to just write formulas using JSL than interactive columns, especially if you happen to mess up with group by column selections even once.
1 Comment
Sarah-Sylvestre
Level V
Hi, thank you for taking the time to submit this request; this is great feedback! I will make updates on this wish if there are any changes on the status.
