JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, Dec. 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
We’re retiring the File Exchange at the end of this year. The JMP Marketplace is now your destination for add-ins and extensions.
I would like to see variability charts saved as interactive HTML have interactive features. Variability charts are saved as pictures without interactive features in the latest version of JMP, JMP 14.
Can you provide a dataset/script for the chart you would like to see? I tried a few from the sample data library and they are interactive, but maybe you have different requirements.
I plotted a variability chart for Abrasion vs Shift using Abrasion.jmp table from the sample library and saved the chart as interactive HTML, which automatically opens it up in Internet explorer. When I hover the mouse over the chart, a message pops up saying "this feature is not yet interactive".
I tried the script, the graph in html is not interactive and I still get the same message, "the feature is not yet interactive". All I can do is conceal contents by clicking on the inverted triangles. It is not possible to select data. Just FYI, I am using JMP 14.
Can you tell me any messages you have in the log because it is working for me in 14. Also maybe you have different preferences set under Preferences > Platforms > Variability Chart that could result in different behavior. Which boxes are checked there?
Mine does not show box plots when I run that script (you might have different options checked in Preferences as I mentioned). If you go to the red triangle menu and uncheck "Show Box Plots", does it come out interactive? Does this give you what you need, or are the box plots necessary? I will talk to the developer working on box plots to see why this is box plot is forcing it to static.
If I uncheck "show box plots", it does come out to be interactive. Yes, I need the box plots to show up on a variability chart. Hope this gets fixed in the next release.
