Make Sum quick formula use Sum() function instead of Add()
This post No output result for summation of multiple columns
Change quick formula Sum to use Sum() function instead of + as Sum() is able handle missing values. Optionally add other Sum() option which would use Sum (or rather add Add() which would be using Add() or + and Sum should utilize Sum()).
https://www.jmp.com/support/help/en/18.0/#page/jmp/statistical-functions-2.shtml?os=win&source=appli...
Why is this idea important?
Gives users option have quickly calculated sum column without always running into issues with missing values.
2 Comments
Thank you for submitting this request!
jthi
More or less the same / related but older wish New Formula Column - Sum Function
