Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Lany P' and U' charts are being added in JMP 17. We've considered adding tests for over and under dispersion, but there does not seem to be consensus in peer-reviewed publications on an appropriate method. Do you know of any cited references?
Thanks Steve, we've found that as well. However, no references are cited that we can find. Still looking for a peer-reviewed publications if you come across any.
