Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Lany P' and U' charts are being added in JMP 17. We've considered adding tests for over and under dispersion, but there does not seem to be consensus in peer-reviewed publications on an appropriate method. Do you know of any cited references?
Thanks Steve, we've found that as well. However, no references are cited that we can find. Still looking for a peer-reviewed publications if you come across any.
